olhado
Sep 26, 2018Aspirant
Nighthawk R7800 poor WiFI performance
I use R7800 for almost two years. Until some time ago performance was very good. I have 100/15Mbps internet connection, and I had no problems with the speed. Recently my WiFi performance dropped and ...
- Sep 27, 2018
It's not only wifi drops with the new .58 It has a issue with huge ping spikes and latency. This has been confirmed by dozens of people and the tests have been ran. There is no question .58 firmware is faulty. That said Voxel is a third party firmware that builds on the core GPL of Netgears original code. He adds much needed updates to several outdated packages Netgear uses and also adds features. Info here https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-60sf.48805/ Firmware here. http://www.voxel-firmware.com/Downloads/Voxel/html/index.html If your not comfortable using third party firmware then simply downgrade back to .52 Netgear firmware it works good minus naming connected clients wich is broke in .52.
michaelkenward
Sep 27, 2018Guru - Experienced User
My R7800 sees no wifi dropoff with the latest firmware. So that is not necessarily the solution.
Before heading down the rocky road of alternative firmware, check for interference from the neighbours, and see if it helps to use a different wifi band.
It can also help to reset the router to factory settings after a firmware flash.
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems for some people, especially on the wifi front.
James721
Sep 27, 2018Luminary
- olhadoOct 03, 2018Aspirant
I have installed Voxel's .60sf firmware as you suggested and after a few days of testing, I can say it is much better. I can see no lag spikes and connection is much more stable over WiFi. I need more time to be sure but it seems, that .58 is somehow causing the troubles. Thank you for help ;-).
