Redcoatwright's avatar
Aug 09, 2019
Nighthawk R7800 potentially compromised
Hi all, I'm concerned my router might be compromised. All of the three main people who are connected to it got hit with a random CC charge a while back. Me and my roommate factory reset the router a...
  • Redcoatwright's avatar
    Redcoatwright
    Aug 10, 2019
    I've actually figured this out, I was using an app on the FireTV called "Downloader" which is used to circumvent the FireTV's verification process of applications so you can "side load" different unapproved apps, I don't even remember what I used this for.
    Anyway, it seems that in order to do this, it can't use the IP that is displayed in settings so it must create a couple virtual network devices and get IPs for them so it can download not using the "main" IP.
    Weird situation but glad I figured that out.
    Thanks!
