Jhagelberger
Feb 28, 2023Tutor
Nighthawk r7800 problem with Chromecast with google TV connecting to interent
I recently bought a Chromecast with google TV and every time I try to log on, the device knocks out my internet on my knight hawk x4s router. I have figured it is solely with the Chromecast as everyt...
Jhagelberger
Mar 01, 2023Tutor
Hi. The model is a R7800
The firmware was updated and current as of last night
Problem - When I try to use Chromecast for Google TV the Chromecast makes the router power down and re-start. This only happens with the Chromecast as I have a firestick and have zero issues. This must be a communication problem between the Chromecast and Netgear R7800?
Do I need to turn something off on the Netgear?
Thanks,
John
Mar 01, 2023Guru - Experienced User
You know how many times on there people say "the firmware is current" when its not? Quite a bit as the automatic update checker isn't always the best.
So what actual firmware is on it?
What modem/gateway is it connected to?
You say you just updated the firmware?
Did it start after that?
If so, have you tried a factory reset?
And if that doesn't work, downgrading the firmware?
- JhagelbergerMar 01, 2023Tutor
I updated firmware yesterday to V1.0.2.92
I had the problem before and after updating firmware.
I would not know what firmware to go back to fix the problem so please advise if I need too.
Oh and yes have factory re-set Chromecast several times now to no avail.
- plemansMar 01, 2023Guru - Experienced User
And this is the only device causing issues?
Got a different chromecast you can try? Makes me suspicious that the chromecast is defective and causing the issue
