tsanders92
Mar 07, 2019Tutor
NightHawk R7800 upload speed
Hey all i currently just got my HFC NBN installed yesturday and im with optus
i have just added my nighthawk X4s R7800 router onto my net work and after some changes im getting my full
download s...
- Mar 08, 2019
do you get the same if you use another speed test site? If you do, then I'm out of ideas.
if you modem is a Gateway (modem+router) you need to set it in Bridge mode and use the R7800 as router
microchip8
Mar 07, 2019Master
what is "the latest" firmware? version number is more clear than "the latest"
tsanders92
Mar 07, 2019Tutor
Hey sorry i am currently running 1.0.2.62
- microchip8Mar 07, 2019Master
This is not the latest firmware for the R7800, which is 1.0.2.62
Are you sure you have an R7800?
- tsanders92Mar 07, 2019Tutor
god dam it i ment 1.0.2.62 was typing in a rush haha
Try a factory reset and manual reconfiguration. There are quite a few changes between .58 and .62 firmware
