tsanders92
Mar 07, 2019Tutor
NightHawk R7800 upload speed
Hey all i currently just got my HFC NBN installed yesturday and im with optus
i have just added my nighthawk X4s R7800 router onto my net work and after some changes im getting my full
download s...
- Mar 08, 2019
do you get the same if you use another speed test site? If you do, then I'm out of ideas.
if you modem is a Gateway (modem+router) you need to set it in Bridge mode and use the R7800 as router
tsanders92
Mar 07, 2019Tutor
Hey sorry i am currently running 1.0.2.62
microchip8
Mar 07, 2019Master
This is not the latest firmware for the R7800, which is 1.0.2.62
Are you sure you have an R7800?
- tsanders92Mar 07, 2019Tutor
god dam it i ment 1.0.2.62 was typing in a rush haha
- microchip8Mar 07, 2019Master
Try a factory reset and manual reconfiguration. There are quite a few changes between .58 and .62 firmware
- tsanders92Mar 08, 2019Tutor
okay will give that a try after dinner ya i got all the download right just fine with disabling QOS but uploads got me so lost ill get back to you soon
