tsanders92's avatar
Mar 07, 2019
NightHawk R7800 upload speed
Hey all i currently just got my HFC NBN installed yesturday and im with optus i have just added my nighthawk X4s R7800 router onto my net work and after some changes im getting my full download s...
  • microchip8's avatar
    microchip8
    Mar 08, 2019
    do you get the same if you use another speed test site? If you do, then I'm out of ideas.
    if you modem is a Gateway (modem+router) you need to set it in Bridge mode and use the R7800 as router
