tsanders92
Mar 07, 2019Tutor
NightHawk R7800 upload speed
Hey all i currently just got my HFC NBN installed yesturday and im with optus
i have just added my nighthawk X4s R7800 router onto my net work and after some changes im getting my full
download s...
- Mar 08, 2019
do you get the same if you use another speed test site? If you do, then I'm out of ideas.
if you modem is a Gateway (modem+router) you need to set it in Bridge mode and use the R7800 as router
tsanders92
Mar 08, 2019Tutor
testing it via wired and use speedtest.net
microchip8
Mar 08, 2019Master
- tsanders92Mar 08, 2019Tutor
Just setting to bridge mode now and will let u know
legend :D 92.23mbps down and 18.13mbps Up after changing to bridge mode
im i doing right by my HFC cable goes into the arris modem then WAN out of there to the optus box then port 1 out of there to my R7800
or can i get away without the optus box in the middle??
- microchip8Mar 08, 2019Master
I don't know, try it. I suspect your Gateway in Bridge mode connected directly to the R7800 WAN port will work
okay thanks ya its running atm maybe one day ill try removing and try running straight off the Arris NBN modem
