panthers89
Feb 09, 2017Aspirant
Nighthawk R7800 wifi downloads much less than they should be
Hi. I just recently updgraded Time Warner/Spectrum Internet from 50Mbps to 300Mbps. Purchased new Netgear CM700 modem and connected to my Nighthawk R7800. From router Genie console to modem / from la...
- Feb 09, 2017
I googled "xbox one max Internet speed" and found out you are getting excellent speed to your XBox 1. Take a look at this:
https://www.reddit.com/r/xboxone/comments/3hcbon/xbox_one_connection_speeds_via_wifi/
My step son is getting 100Mbps by hard wiring into my old R7000 that I have set up as a bridge in his room. The R7000 is supplying 340Mbps to his laptop when it is wired to it. I have both my main R7900 and bridge R7000 setting up about chin level and about 35~40 feet apart with two walls in between them.
If you want better speed than you currently have you might want to pick up a R7000 or go to COSTCO and pick up a R6900 on sale for $139.99 until 2/28/17.
LeeH
Feb 09, 2017Prodigy
I was looking at the specs on your Lenovo X220 laptop. It looks like it didn't come with 5GHz AC wireless when new. Are you using a USB network adapter for 5GHz? I know this laptop has USB2 ports.
- panthers89Feb 09, 2017Aspirant
Ah, so maybe I am client limited on that one. Excellent point. It was letting me connect to the 5ghz network so I assumed it supported it. I guess it lets you join but throttles you to what it can support? The Xbox One should be quicker though right? So, 80's and 90's is what you're seeing/expect on your Xbox one?
- LeeHFeb 09, 2017Prodigy
