panthers89's avatar
panthers89
Nighthawk R7800 wifi downloads much less than they should be
Hi. I just recently updgraded Time Warner/Spectrum Internet from 50Mbps to 300Mbps. Purchased new Netgear CM700 modem and connected to my Nighthawk R7800. From router Genie console to modem / from la...
  • LeeH's avatar
    LeeH
    Feb 09, 2017
    I googled "xbox one max Internet speed" and found out you are getting excellent speed to your XBox 1.  Take a look at this:
    https://www.reddit.com/r/xboxone/comments/3hcbon/xbox_one_connection_speeds_via_wifi/
    My step son is getting 100Mbps by hard wiring into my old R7000 that I have set up as a bridge in his room.  The R7000 is supplying 340Mbps to his laptop when it is wired to it.  I have both my main R7900 and bridge R7000 setting up about chin level and about 35~40 feet apart with two walls in between them.
    If you want better speed than you currently have you might want to pick up a R7000 or go to COSTCO and pick up a R6900 on sale for $139.99 until 2/28/17.
