Yamster931
Dec 06, 2022Aspirant
Nighthawk R7800 X4S AC2600
DUMAOS V2.3.2.22 A7Legit Hi this is all I want is to have a VPN on my router so everthing connected to it goes thru the vpn instead of putting a seperate app onto everyhing. I have a paid subscripti...
Dec 06, 2022Guru - Experienced User
dumaos isn't available for the r7800.
So what do you actually have?
Yamster931
Hi, here is a screen shot of my Control Panel router if this explains what I mean better.
Nighthawk R7800 X4S AC2600.
- plemansDec 06, 2022Guru - Experienced User
didn't know the R7800 had dumaos for the r7800 or if thats just how it shows up for the xr500 (since hardware wise its similar)
- Yamster931Dec 06, 2022Aspirant
Thanks for replying, but back to my original question any ideas how I go about putting Surfshark VPN on the router,
thanks in advance.
- FURRYe38Dec 06, 2022Guru - Experienced User
This isn't supported on the R7800. I believe there was a initial beta back then that NG and Duma loaded on R7800s during this time frame. Then after the XR series routers were officially released. NG removed support for the Duma OS on R7800s. Only R7800 stock FW is officially supported on the R7800. This would not be support or allowed on R7800s. Unless you modified the Duma FW to load on the R7800, then that's your choice. NG and NetDuma develop the Duma OS only for the XR series of routers. Adding features as well isn't supported. Only what comes loaded in stock FW is supported.
If your wanting to do more with the R7800, I recommend trying Voxel FW for the R7800 over on smallnetbuilder forum:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
