Yamster931
Dec 06, 2022Aspirant
Nighthawk R7800 X4S AC2600
DUMAOS V2.3.2.22 A7Legit Hi this is all I want is to have a VPN on my router so everthing connected to it goes thru the vpn instead of putting a seperate app onto everyhing. I have a paid subscripti...
Yamster931
Thanks for replying, but back to my original question any ideas how I go about putting Surfshark VPN on the router,
thanks in advance.
Dec 06, 2022Guru - Experienced User
This isn't supported on the R7800. I believe there was a initial beta back then that NG and Duma loaded on R7800s during this time frame. Then after the XR series routers were officially released. NG removed support for the Duma OS on R7800s. Only R7800 stock FW is officially supported on the R7800. This would not be support or allowed on R7800s. Unless you modified the Duma FW to load on the R7800, then that's your choice. NG and NetDuma develop the Duma OS only for the XR series of routers. Adding features as well isn't supported. Only what comes loaded in stock FW is supported.
If your wanting to do more with the R7800, I recommend trying Voxel FW for the R7800 over on smallnetbuilder forum:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
- Yamster931Dec 06, 2022Aspirant
thanks, i bought the router secondhand came as it is, so could i revert it back to stock netgear firmware?
- FURRYe38Dec 06, 2022Guru - Experienced User
Ah I see...so someone may have been on the beta team back then or could have modified the Duma OS to load on it and didn't remove it.
You can try putting the stock FW back on using the web page UI, I believe that should work. IF not, you may need to use the TFTP method to directly put stock NG FW back ON and blow the Duma OS away.
thank you, how far back in the stock net firmware will I have to go i`ve tried V1.0.0.28 it trys to flash thru update control panel but after 15mins still no change after I Reboot it.
- michaelkenwardDec 06, 2022Guru - Experienced User
Indeed. The first DumaOS router was built around the R7800 hardware.
But that was in 2017 and the two OS systems parted company a long time ago.
Yep.
There was someone I made contact with a few years ago that could make mods. But that didn't seem to last.
