macdanif
Nov 09, 2021Tutor
Nighthawk R7850 Losing DNS after latest firmware update
I have a Nighthawk X6 R7850. I have it connected to a Spectrum Cable Modem. After the latest firmware update, I have noticed it randomly loses DNS. What I mean by this, is that DNS resolution fail...
Nov 09, 2021Guru - Experienced User
Its happened across multiple product lines.
Some have been fixed by enabling ipv6
others by using a different dns provider.
And some have had to downgrade the firmware back a version.
Not sure what method will work best for you.
macdanif
Nov 09, 2021Tutor
I did see another article for a different model where doing factory reset resolved the problem. I have done that today and restored my settings. Will give it a couple days and see how it goes.
- plemansNov 09, 2021Guru - Experienced User
Let us know if that solution worked for you!
