capperrice
May 27, 2022Star
Nighthawk R7900 2.4 ghz
Running the latest V1.0.4.46_10.0.53 on R7900 Nighthawk. Recently my 2.4ghz (both guest and main SSID) won't connect to Internet. All devices that are connected to it (printer, smart bulbs etc) lose ...
May 30, 2022Guru - Experienced User
What modem/gateway is it connected to?
- capperriceMay 30, 2022Star
It is connected to a FIOS Modem of Frontier. It has its own 2.4 and 5 but it has a different name and has been switched off. Even though I cannot connect to the wireless of Frontier Cable Modem, both SSDs do show up as available. I am planning to reset this FIOS modem as well.
I am uploading a older version of firmware 1.0.3.18_10.0.42 (20191024 Release notes) as I do remember that this problem was not there about 2 years ago.I will reenter my settings manually after the downgrade instead of uploading a configuration file.
Will post results.
- plemansMay 31, 2022Guru - Experienced User
turning off the wifi doesn't disable the frontiers router functions. it leaves you in a double nat. It normally doesn't cause much issues but occasionally it does.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode- capperriceJun 14, 2022Star
I removed the Frontier Router completely. When I talked to them, apparently I didn't need it at all. So I connected R7900 directly to the wall and backdated the firmware to R7900-V1.0.3.18_10.0.42.chk.
Rebooted the modem - all works fine. Two 5ghz, One 2.4ghz wifi doing great - for a couple of days. 2.4ghz is again behaving weird. Sometimes it allows new connections but without internet OR doesn't allow new connections at all.
I changed settings to different security levels for the 2.4ghz (SSID is one word - Kaplan) - no success!
During this process, both 5ghz channels work great!
Hardware issue perhaps?
