MJHgamer
Jul 22, 2024Aspirant
Nighthawk R7900
Nighthawk X6 R7900 Firmware Version V1.0.4.46_10.0.53 1. Login is not https despite clicking on Always Use HTTPS to Access Router under Web Services Management. How do I fix that? 2. How do I se...
michaelkenward
Jul 22, 2024Guru - Experienced User
Why do you want to fix it?
That seems to be a remote access thing. Enable https there and all hell breaks loose.
2. How do I setup a firewall/antivirus so everything wired or wireless through it will be protected without messing up our television viewing or access to most websites? Currently, we only have protection on our computers and cell phones independently.
What problems do you have? What firewall/antivirus do you want to set up?
MJHgamer
Jul 23, 2024Aspirant
I have never setup a firewall or know anything about doing so with a router. I only know that they usually have one built in. As for the biggest issue, logging into the router it isn't doing https...in the browser bar it shows it crossed out in red.
