AKCoach
Jul 07, 2024Aspirant
Nighthawk R7900P - can't' reserve IP address - responds with invalid MAC address
Nighthawk R7900P - Firmware Version V1.4.4.94_1.3.56 I'm trying to reserve IP address for a device (ARLO home security base station) that is currently attached and functional. When I check the...
- Jul 07, 2024
You'll need to revert back to prior working FW version as NG hasn't put out a beta for the R7900P since it's EoL.
Sorry.
michaelkenward
Jul 08, 2024Guru - Experienced User
What are you doing?
Why do you want to do that?
Arlo hubs don't need that sort of tweaking.
I have two or three on line at any one time. No IP address reservation needed.
- AKCoachJul 08, 2024Aspirant
Without a reserved IP address, if there's a power outage and my router restarts, the Arlo gets a newly assigned random IP address. I do not use Arlo's subscription service; I store saved videos locally. In order to view the video library when not on my home LAN, the ports for the Arlo IP address must be forwarded. If the IP keeps changing, I can't view the library, so when I receive a message that something triggered the Arlo camera, I am unable to see what that was. By rolling back the firmware as the first response indicated, this problem as been solved.
- FURRYe38Jul 08, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
