JDub75
Nov 14, 2022Aspirant
Nighthawk R7900P - slow internet speeds
I *just* upgraded our home internet to Spectrum with up to 300 mbs. However, after connecting the Spectrum modem to the Nighthawk router, the 2.4 Ghz channel tested at around 30 mps and the 5 Ghz tested at 140 mbs... well under the service speed. The tech said we are receiving the 300 mbs into the house and he installed a new amplifier as well at the point of entry. I did some searching on the community boards and made the recommended changes but still have not seen any irmprovement:
- Modem to Router connection Ethernet
- turn off QoS,
- turn off Parental Controls
- turn off Traffic Meter
- no blocking services are enabled
- selected channel 36 for the 5 Ghz
- autodetect for 2.4 Ghz
- 20/40 coexistence enabled
- beamforming enabled
- MU-MIMO disabled
- DHCP on
R7900P — Nighthawk X6S AC3000 Tri Band WiFi Router
Firmware - V1.4.4.94_1.3.56
Can someone assist in what I need to do next to get near the speeds we are now paying for? Thank you!
What speed do you get hardwired into the router?
- JDub75Aspirant
The service into the modem (co-axial) is 300 mpbs download. From the Spectrum modem it's via ethernet directly into the Nighthawk Router. Unfortunately, I don't have an ethernet port on my Mac but I ran a few tests to check the speed on the different frequencies on both my Mac and my iPhone with different distances in the house. We also have a Netgear Extender/Booster (EX2700) to help boost the signal to the downstairs area.
2017 Macbook 13"
OS: Mojave 10.14.6
2.3 GHz Intel Core i5
iPhone 12 Pro
sw ver 14.7.1
1. Next to the Nighthawk Router (2nd floor)
Macbook:
5 Ghz - 349 mbs
2.4 Ghz - 79 mbs
2.4 Ghz Ext - 21 mbs
iPhone:
5 Ghz - 345 mbs
2.4 Ghz - 98 mbs
2. Downstairs (kitchen area) directly down the hall (1st floor)
Macbook:
5 Ghz - 210 mbs
2.4 Ghz - 58 mbs
2.4 Ghz Ext - 37 mbs
iPhone:
5 Ghz - 140 mbs
2.4 Ghz - 26 mbs
2.4 Ghz Ext - 28 mbs
After the tests, a few things I was considering... moving the Nighthawk router to a lower position. It's currently on the top of the 2nd floor landing / staircase. The position is higher than the 1st floor ceiling but inline with the hallway which leads to the downstairs area; pretty much a straight shot. Do you think it's possible it may increase the speeds having a more direct line of sight? The other consideration is buying a dual channel booster/extender to help carry the 5.4 Ghz channel downstairs. The current extender only supports one 2.4 Ghz channel. If I remember correctly, the 5.4 Ghz channels have a more limited range.
I'm open to suggestions or next steps. Thank you.
- KitsapMaster
What application are you using to test throughput capacity? Recommend Ookla from the play store.
A couple of other configuration changes for testing. Disable 20/40 consistence, disable smart connect, and manually select either channel 6 or 11 on the 2.4 GHz band.
After you have made a series of changes to the configuration to your router, it is a good idea to power down the router and disconnect the power cord. Reconnect the power and boot the router giving it plenty of time to stabilize. Then run your tests.
