NetOp
Mar 25, 2022Tutor
Nighthawk R7900P X6S AC3000 Latest Firmware v1.4.2.84 Destroys DNS resolution
Dear Netgear, You have absolutely destroyed the functionality of my R7900P router with the new firmware release v1.4.2.84. Web sites never load the first time and many DNS queries timeout. Please...
Mar 25, 2022Guru - Experienced User
have you tried enabing ipv6 and then rebooting the router and devices?
thats fixed it for some.
Others have needed to downgrade.
- NetOpMar 25, 2022Tutor
IPv6 is already enabled and but I tested again for good measure (when I can get DNS to load). Continuous ping works perfectly when DNS resolution works but more often than naught the first attempt to load a web page fails DNS resolution. I don't have any special settings in the router except a couple of DHCP reservations.
- plemansMar 26, 2022Guru - Experienced User
One other option you can try before downgrading is to setup different dns servers for both the ipv4 and ipv6 settings.
Have you tried that?
If so and you're still having issues, downgrade the firmware a version.
- NetOpMay 31, 2022Tutor
Firmware Version
V1.4.3.88_1.3.50Is still broken SINCE RELEASE with a bunch of ineffective workaround posts and lack of real Netgear support. Netgear has essentially bricked my router through negligence. I have tried multiple IPv6 workarounds and complete resets. Netgear needs to take this seriously and be accountable or Ill keep posting about their maleficence and sharing the terrible experience they have brought to me as a paying customer.
