Va_tech90
May 14, 2021Aspirant
Nighthawk R7900P X6S setup issues
I have been trying to set up my R7900P WiFi router all afternoon and each time I get to the point where it says it’s configured and I click “Next”, it idles for about a minute or two then says it enco...
michaelkenward
May 16, 2021Guru - Experienced User
Va_tech90 wrote:
And you’re “one of them”. Thanks, I’ll find my answers elsewhere. Have a great day!
Good luck.
Forgive me, I should have added that Netgear supports new purchases at no cost to you.
You have up to 90 days to get them to help you to set up new stuff .
You do it via the support portal:
Contact Us | Support | NETGEAR
First you have to register your device to confirm that it is eligible for the 90-days free support. Start here:
MyNETGEAR | Product Registration
Start a case and, with luck, they will contact you.
A word of advice, when you talk to support people, or anyone else you ask for help, it is a good idea not to come come across like you think the world revolves around you. That means being prepared to answer questions as clearly as possible, and not shouting at them if they don't come up to your high standards. After all, the support grunts are not sitting in front of your computer and have no idea what you are doing and what you see.
Va_tech90
May 16, 2021Aspirant
Thanks for the advice. Now leave my world.
