Gipper4u's avatar
Dec 01, 2021
Nighthawk R7960P - possible to change DNS server assigned by DHCP?
Is it possible to set DHCP to assign a specific DNS server?  I don't see any way to do it.  I want all my clients to use 1.1.1.1, 1.0.0.1
  • On the routers web page under Advanced Tab/Setup/Internet you can input custom DNS.
  • FURRYe38's avatar
    • Gipper4u's avatar
      Gipper4u
      Tutor
      Thanks, I saw that but I'm not sure if it truly changes what the client is given via DHCP.  Unfortunately, nslookup returns the router address as DNS when done that way. When I manually change my computers adapter to 1.1.1.1, nslookup shows it as being used for lookups.  I'll accept the answer, but when I get some free time, I'll see if I can verify with wireshark.  The reason I'm asking is because I'm getting constant
      "DNS_PROBE_FINISHED_NXDOMAIN" errors and the only thing that seems to resolve it is manually entering DNS on my clients.   Thanks!
