Xephisol
Nov 27, 2022Aspirant
Nighthawk R7960P Lag and DNS Issues -- I'm losing my mind!
I'm at my wits end with this router. Back in July 2022, my father gifted me a Nighthawk R7960P router. Being the IT geek and avid gamer I am, I figured this router would be more than enough for mys...
Xephisol
Nov 29, 2022Aspirant
I activated IPv6 and did not notice any changes in my network performance. I think it's worth noting, I have not had NXDOMAIN DNS issues recently. After setting the DNS manually on the router and computer, they went away for a while. At least, they don't pop up nearly as much as before. I think IPv6 helped with this as I still didn't have any issues.
Now, I'm still having latency issues. I verified it's not just the game I've been playing (CoD MWII) as I had the same issues with Rocket League and Fall Guys. All three of those games were launched from different launchers for variation as well. I can't quite figure out what the cause of the issue could be.
We rarely have issues with streaming and I get about 380mbps down with Spectrum, so buffering shouldn't be much of an issue. It's like the games get hung up sending data because the lag spikes come in waves. I'll start a game with about 40ms of latency, and then it spikes up between 220ms and 380ms, then settles. The latency just fluctuates from there.
I know there is real possibility that it's not the router, but I don't have these issues on other networks when I game. Any helpful tips?
Nov 29, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Might try running a www.pingplotter.com test with a wired PC connected to the ISP modem/ONT to check for any issues here. Then do same with the router in the middle with the WIFI AND ALL other devices disconnected from the modem accept for the one testing PC.
Are you gaming over wireless or wired connection? Wired is preferred.
- XephisolDec 06, 2022Aspirant
FURRYe38 Here is the information you requested:
MFR: Technicolor DOCSIS 3.1
Model: EU2251
I use wireless connection, but there's no major drop-off between hardwired and wireless (as shown in attached images). Wire is CAT5E, but might make a purchase for CAT6 or higher soon.
I ran pingplotter and these are the results:
As you can see by the results, there isn't too much variation. But, it looks like the connection gets severely hung up at one of the netops.charter.com locations. Not sure what to do with this information, so I'm hoping you could assist me at least a little bit. I think this is a mix of issues between the router and the servers in my area.
- FURRYe38Dec 08, 2022Guru - Experienced User
There not too much we can do with anything past the ISP modem.
This ISP modes are not the best. Might ask the ISP if there is something newer or if you can use you own modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlSet up IPv6 (Auto) on the R7960P and you should be fine. No specific configurations are needed.
- XephisolDec 15, 2022Aspirant
I wanted to finally reach back out and give an update.
I just had the ISP here and it appears there's two issues at once. Upon investigating, the coax line to the service was above 12ghz (or whatever the increment is) from channel 76 and up which was causing some increased connectivity issues. By implementing a 10gb splitter, the signal is now in the 9's and not being overloaded. He stated he believes the router was pulling too much power from the ISP pod in my apartment complex since it tries to manage so much traffic. That's one part of the issue.
After using pingplotter some more, I'm getting about 50% packet loss on the router itself. Every half second, there is complete packet loss and then no packet loss. The latency issues connecting to that earlier server were mitigated slightly, but I'm still having latency issues. To resolve this, I am going to go ahead and factory reset the router, as well as update the firmware over ethernet. Then from there, I'm going to start setting up everything manually.
It sucks that there have been so many issues. I want to love this router, but with all the pain it's causing I'm starting to despise it. Unfortunate, but I'm frustrated.
I'll provide an update as soon as I get some substantial results. I will attach some screenshots as reference to my earlier paragraph to show what I'm getting on the router with packet loss.
