sak2806
Apr 06, 2018Aspirant
Nighthawk R800 - Firmware Control
Hi There, It's my first post so please be gentle. We recently bought a Nighthawk R800 and have been loving it, but today our router restarted due to a firmware update is there any way we can auto swit...
- Apr 10, 2018
Suspected there was no auto-update but would claim there wasn't. The latest F/W, V1.0.4.12 did come out a long time ago, so I'd think if there was auto-update involved it would have happened maybe sometime last month if staged out over a few weeks.'
More than likely it was a modem or ISP line going down?
schumaku
Apr 06, 2018Guru - Experienced User
Welcome to the Netgear Community!
Assuming all Nighthawk routers use the same UI menu structure, check [Advanced] -> Administration -> Firmware Update -> Router Auto FIrmware Update
Keen to learn if your new installed R8000 has this enabled by default - what would be a strange decision.
sak2806
Apr 10, 2018Aspirant
This is what I have, Any solutions?
- schumakuApr 10, 2018Guru - Experienced User
Amazing AbhayB NaderA - a router with Auto Update enabled by default, and no user control to disable? Design, development, and implementation seems to run out of any control.
- AbhayBApr 10, 2018NETGEAR Employee Retired
There's clearly misunderstanding that R8000 even has auto-update firmware. Secondly, all Nighthawks that have auto-firmware update feature has ability to opt-out through advanced setting. So I am not sure where this issue is coming from.
- IrvSpApr 10, 2018Master
