Cajeel
Aug 14, 2021Tutor
Nighthawk R8000 - Problème DNS
Bonjour, J'ai effectué la mise à jour 1.0.4.74 de mon routeur. Mise à jour qui ne s'est pas déroulé convenablement. Après plusieurs échec, un reboot a finalement installé la mise à jour. Après...
- Aug 14, 2021
You're not the only one we've seen with dns issues on the forum.
I'd stick with the downgrade for the time being.
Aug 14, 2021Guru - Experienced User
- CajeelAug 14, 2021TutorHi, thanks for your answer.
The latest firmware updates security settings, so I hope it will be fixed soon.
You tell me it's not uncommon, in my investigations i saw some other netgear routers with the same problem, it would be nice to test firmwares before release.
Anyway, thanks for your answer- plemansAug 14, 2021Guru - Experienced User
the generally do test firmwares prior to release (been on 1 or 2 myself for other devices). But its different from testing on several combinations of routers/modems/setups to millions of variable combinations.
- CajeelAug 14, 2021TutorYou're right.
There are several possibilities and configurations.
I didn't think about that.
I didn't want to offend, i just wanted to signal a problem 😉
The solution has been found,so no worries.
