Cajeel
Aug 14, 2021Tutor
Nighthawk R8000 - Problème DNS
Bonjour, J'ai effectué la mise à jour 1.0.4.74 de mon routeur. Mise à jour qui ne s'est pas déroulé convenablement. Après plusieurs échec, un reboot a finalement installé la mise à jour. Après...
- Aug 14, 2021
You're not the only one we've seen with dns issues on the forum.
I'd stick with the downgrade for the time being.
Aug 14, 2021Guru - Experienced User
Cajeel
Aug 14, 2021Tutor
Hi, thanks for your answer.
The latest firmware updates security settings, so I hope it will be fixed soon.
You tell me it's not uncommon, in my investigations i saw some other netgear routers with the same problem, it would be nice to test firmwares before release.
Anyway, thanks for your answer
