Cajeel
Aug 14, 2021Tutor
Nighthawk R8000 - Problème DNS
Bonjour, J'ai effectué la mise à jour 1.0.4.74 de mon routeur. Mise à jour qui ne s'est pas déroulé convenablement. Après plusieurs échec, un reboot a finalement installé la mise à jour. Après...
- Aug 14, 2021
You're not the only one we've seen with dns issues on the forum.
I'd stick with the downgrade for the time being.
Cajeel
Aug 14, 2021Tutor
Hi, thanks for your answer.
The latest firmware updates security settings, so I hope it will be fixed soon.
You tell me it's not uncommon, in my investigations i saw some other netgear routers with the same problem, it would be nice to test firmwares before release.
Anyway, thanks for your answer
Aug 14, 2021Guru - Experienced User
the generally do test firmwares prior to release (been on 1 or 2 myself for other devices). But its different from testing on several combinations of routers/modems/setups to millions of variable combinations.
- CajeelAug 14, 2021TutorYou're right.
There are several possibilities and configurations.
I didn't think about that.
I didn't want to offend, i just wanted to signal a problem 😉
The solution has been found,so no worries.- plemansAug 14, 2021Guru - Experienced User
Sorry, wasn't meaning to sound rude.
It gets a bit frustrating even for those of us on here when Netgears firmware breaks things.
