Dadicator
Dec 01, 2018Initiate
Nighthawk R8000 AC3200 - SSID is Not Broadcasting
I have looked high and low for answers: My Router stop Broadcast the "Second Channel on the 5Ghz Side" - The first channel shows up fine - as does the 2.4Ghz channel. I do not have Smart Connect tu...
- Dec 02, 2018
"Nighthawk R8000 AC3200 - SSID is Not Broadcasting" ==> First of all - This is a Forum to help convey information about an issue - Not Trying to step on anyones toes here! Router Firmware is V1.0.4.28_10.1.54 as Stated - Computer is Windows 10 PRO V1803 - I do Use Virtual WIFI & HyperV on my Computer.
My Router was updated from a older version of the firmware when V ' .28 came out. My Windows 10 machine updates as needed. My Region is USA.
Like I Stated SSID is Not Broadcasting on Second Channel (I did not say it did not work), and YES I can Access it Manually by Typing in the SSID and manually setting up.
The Reason I said that it could possibly be Compatiblity with the firmware and Microsoft Secuity Updates - Is becuase it was working FINE before the update. Most of the Firmware Patches are Security Related, Same is with Microsoft. As to my Reasoning, Deductions, and Trouble shooting - This is based on 40 years of working with computers and Degree and Field Work in System Administration & WAN technolgies dating back to the late 70's.
I do not have all the answers - I can only relay what I have experienced and what happened to my Computer - This may or may not be the issue with all computers. ==> The work around would be to Set the WiFi Manually and see if that will work for you.
Dadicator
Dec 02, 2018Initiate
Dadspet
Dec 02, 2018Aspirant
Sounds like exactly the same issue I have. I just updated my R8000 to the latest firmware level 1.0.4.28_10.1.54. Before the update I could connect to netgear68-5-2 and after the update i can't connect to it. I tried 1 cell phone, FireHD10 Gen7 and W10 Laptop.. The 5-2 light is Lit on the router. Some of my devices seem to show 5-2 aa not in range?
