piotr_dobrogost's avatar
Mar 06, 2021
Nighthawk R8000 DHCP on WAN port not working
I replaced Netgear WNR3500L with Netgear R8000. I had WNR3500L's WAN port connected to TP-LINK TD-W8960N DSL modem (setup in router mode) and obtaining IP address and DNS servers from it using DHCP. ...
  • antinode's avatar
    Mar 06, 2021
    > [...] I have "Internet IP Address" set to "Get Dynamically from ISP"
    > in "Internet Setup". [...]
       What about all the other Internet Setup settings?  Did you try
    letting the set-up wizard do what it does?
    > [...] Why?
       Who knows?  With my weak psychic powers, I can't see any of the LED
    indicators on any of your devices, or any of the R8000 Internet Setup
    settings (save one), or the configuration of your old WNR3500L.  Could
    be a bad Ethernet cable, for all I know.
       If you connect a computer to the TD-W8960N, does _it_ get good IP
    parameters?  (Namely?)
    > [...] TD-W8960N DSL modem (setup in router mode) [...] "I connected
    > R8000 the same way [...]
       Why, exactly, are you arranging a cascade of routers, instead of
    using one router (modem and router, or modem+router and wireless access
    point)?  Cascading multiple routers can cause multiple problems (double
    NAT, for example), even when you get such an arrangement to work.
