AirRock
Apr 02, 2021Initiate
NightHawk R8000 ethernet working but wifi stops working after several days
Hey, I've been experiencing an issue with at least the most recent firmware version V1.0.4.68_10.1.75. I'm testing rolling back to V1.0.4.66_10.1.75 as a troubleshoot. The issue is that the ...
- Apr 03, 2021
did you try a factory reset?
Some have downgraded to the 1.0.4.28 version of the firmware, doing a factory reset, and then reinstalling the router. (disable auto updates). Reason why is some of the r8000's didn't play nicely with netgear armor. this is the firmware version prior to armor
Apr 03, 2021Guru - Experienced User
AirRock
Apr 03, 2021Initiate
Thanks! I'll give that a shot later today!
