OtisCampbell's avatar
Nov 24, 2021
Nighthawk R8000 goes offline
My router is consitently losing or dropping its internet connection.  I am running firmware v1.0.4.76_10.1.82.  My ISP, Frontier Communicatoins, provide me with a modem/router.  I have that modem connected to my Nighthawk via a network cable.  When the Nighthawk loses internet our connected devices lose their internet connection (I know that is obvious I'm just trying to be thorough). However I know the Frontier modem is connected to the internet because my wired devices, i.e. Xbox, desktop computer, continue to have internet access.
It is possible that this is only a problem on the 5GHz band.  For example, right now my iPhone has no connection but my Rokus and smart plugs do.
This started a few weeks ago and seems to be happening more and more frequently.
  • plemans's avatar
    What modem/router is it connected to?
    Is the gateway in passthrough/modem only mode?
    Or the netgear in access point mode?
    • OtisCampbell's avatar
      OtisCampbell
      Tutor
      My Netgear router is connected to an Arris NVG468MQ router.
      I don't know how to find the answers to your questions
      • plemans's avatar
        That gateway is a modem/router/moca adapter combo device.
        it causes a double nat which can create some network instability.
        A double nat happens when you cascade more than 1 router.
        https://kb.netgear.com/30186/What-is-Double-NAT
        Fixes? There’s 3 options but only use 1.
        1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
        2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
        3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
        https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
        Probably the easiest option to to put the netgear in AP mode. But there are drawbacks as outlined above.
