Chrisd01's avatar
Chrisd01
Follower
May 09, 2023
Nighthawk R8000 Guest Network Problem
My son turned off the Guest Network and now when I try to get it back on - it wants me to enter the password which I do and then it says it is applying the configuration and then it tells me there is an error.   I cannot get the Guest Network turned back on - any ideas?
Thanks for your help.
1 Reply
  • FURRYe38's avatar
    Factory reset the router and setup from scratch with a wired PC and web browser...
