Dave67
Oct 27, 2020Initiate
Nighthawk R8000 not seeing USB drive
I have had this R8000 X6S AC4000 router for a few months and just bought a new Seagate backup plus portable HDD 4TB, model STHP4000400. I can plug it into either the 3.0 or 2.0 ports. The HDD indicat...
- Oct 27, 2020
> [...] a new Seagate backup plus portable HDD 4TB, model STHP4000400.
> [...]With which file system? (Hint: exFAT may not be the best answer.)
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Share a USB
Storage Device Attached to the Router" and "USB Device Requirements".> I looked through other posts, and did not find a solution.
No actual information there. Perhaps you selected the wrong "other
posts".
antinode
Oct 27, 2020Guru
posts".
- Dave67Oct 28, 2020Initiate
yeah... I knew I was overlooking something very simple. The drive comes formatted as exFat... reformatted it to NTFS, works like a charm.
Thanks
