Dave67's avatar
Dave67
Initiate
Oct 27, 2020
Nighthawk R8000 not seeing USB drive
I have had this R8000 X6S AC4000 router for a few months and just bought a new Seagate backup plus portable HDD 4TB, model STHP4000400. I can plug it into either the 3.0 or 2.0 ports. The HDD indicat...
  • antinode's avatar
    Oct 27, 2020
    > [...] a new Seagate backup plus portable HDD 4TB, model STHP4000400.
       With which file system?  (Hint: exFAT may not be the best answer.)
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Share a USB
    Storage Device Attached to the Router" and "USB Device Requirements".
    > I looked through other posts, and did not find a solution.
       No actual information there.  Perhaps you selected the wrong "other
    posts".
