nmpth
Jun 20, 2022Tutor
Nighthawk R8000 one of the 5GHz is not working
Hi Experts, Device: Netgear Nighthawk X6 AC3200 FW Version: v1.0.4.84 My Nighthawk R8000 X6 is broadcasting two 5GHz SSIDs. One of them is using Channel 44 (Radio 1) and other one is using Chan...
Jun 20, 2022Guru - Experienced User
What error do you get when you try to connect?
did you try a simple factory reset?
