75BraVo
Feb 17, 2023Aspirant
Nighthawk R8000 Port forwarding invisible?
On my R8000 I know that there are Portforwardinge configured. The problem is, I can't see them. If I create a new Port Forwarding, it's visible in the list. But I can't see the existing ones - and t...
- Feb 20, 2023
Changing the language had no effect. In the end a factory reset and annoying reconfiguration fixed the problem.
Feb 17, 2023Guru - Experienced User
What browser are you using?
Does this happen in a different browser or computer?
- 75BraVoFeb 17, 2023Aspirant
Happens in Firefox and Safari on two different PCs.
Firmware is V1.0.4.84_10.1.84
Internet Modem is a Telekom Hybrid Router from Deutsche Telekom, but I'm pretty sure it has nothing to do with the invisible but active port forwardings in the Netgear Router.
- FURRYe38Feb 17, 2023Guru - Experienced User
Could you try Opera on one of the PCs?
Do you disable uPnP before setting up any PF configurations?
Can you post a screen capture of the PF configuration page please.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerIs the modem in router mode or modem only mode? If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode- 75BraVoFeb 17, 2023Aspirant
Now I tried Opera with no better result. Only one entry is displayed in the list. There are at least 5 active PFs. 4 of them active for a long time.
The ISP Modem is only in Modem mode. No double NAT. My PFs are not new. I entered them some month ago in the NG. They are still working but disappeared in the UI.
No, there was no factory reset of the NG and I really want to avoid that if possible because it would be a lot of work to set up everything again.
