75BraVo's avatar
75BraVo
Nighthawk R8000 Port forwarding invisible?
On my R8000 I know that there are Portforwardinge configured. The problem is, I can't see them. If I create a new Port Forwarding, it's visible in the list. But I can't see the existing ones - and t...
  • 75BraVo's avatar
    75BraVo
    Feb 20, 2023
    Changing the language had no effect. In the end a factory reset and annoying reconfiguration fixed the problem.
