75BraVo
Feb 17, 2023Aspirant
Nighthawk R8000 Port forwarding invisible?
On my R8000 I know that there are Portforwardinge configured. The problem is, I can't see them. If I create a new Port Forwarding, it's visible in the list. But I can't see the existing ones - and t...
- Feb 20, 2023
Changing the language had no effect. In the end a factory reset and annoying reconfiguration fixed the problem.
Kitsap
Feb 17, 2023Master
For testing purposes, you could change the router display language to English and check your port forward list?
75BraVo
Feb 20, 2023Aspirant
- KitsapFeb 20, 2023Master
75BraVo wrote:Changing the language had no effect. In the end a factory reset and annoying reconfiguration fixed the problem.
Recommend you save a copy of your configuration file. It makes the reconfiguration less annoying. When you do so, in the file name include the firmware version that was installed when the configuration file was created. Sometimes importing an old configuration file does not work as it is not compatible with the current firmware version.
