lychaeus's avatar
Dec 10, 2019
Nighthawk R8000 Slow Internet Speeds
Hi everyone,   Recently upgraded my internet from 500mb/s to a gig. Previously, my internet speeds on my 5Ghz wifi hovered at around 350-400 up/down. Over direct connection to the router, about 450...
  • lychaeus's avatar
    lychaeus
    Dec 11, 2019
    Hi Plemans,
    I solved my issue. The issue had to do with the firmware which I was able to downgrade. It completely fixed the issue.
    Currently, I am using R8000-V1.0.4.18_10.1.49
    However, I will answer these questions anyways.
    House materials?
    Mainly wood and drywall
    How many sq ft is your house? Levels?
    Not sure about sq feet, but two levels, but I am right next to my router.
    What are you testing the speeds with?
    Both wired connection directly to the router as well as wireless on the 2.4Ghz band and the two 5Ghz bands. I have also tested under a wired connection directly to the modem itself.
    What website are you using for speed testing?
    I've used my ISP's test, Speedtest.net, and a several others.
    Have you tried moving the router to see if its placement related?
    No, it's not placement related.
