syntax
May 20, 2024Aspirant
Nighthawk R8000 still get updates?
Hi, Does the NightHawk X6 what is the latest Firmware for it and What power supply is good to use for it?
May 20, 2024Guru - Experienced User
Last one is here:
Most likely the last one.
https://www.amazon.com/332-10788-01-2ABS060K1-AD-6019R-0335A1960-CPA09-004A/dp/B0B9G7GWJL/ref=sr_1_5
Should work good.
- cmp123May 28, 2024Aspirant
can you still use a 14v or 12v power for router?
- FURRYe38May 28, 2024Guru - Experienced User
Only use the voltage and amp specs from what is on the sticker on the power adapter or seen on the back of the router.
Can see the specs in the spec data sheet on NGs web site I believe.
- cmp123May 29, 2024Aspirant
I want to know would I be safe with 12V I know most router use it
