syntax
May 20, 2024Aspirant
Nighthawk R8000 still get updates?
Hi, Does the NightHawk X6 what is the latest Firmware for it and What power supply is good to use for it?
cmp123
May 28, 2024Aspirant
can you still use a 14v or 12v power for router?
May 28, 2024Guru - Experienced User
Only use the voltage and amp specs from what is on the sticker on the power adapter or seen on the back of the router.
Can see the specs in the spec data sheet on NGs web site I believe.
