QmanRocks
Jul 09, 2021Aspirant
Nighthawk R8000 stuck in AP mode
I recently set up a router for my own room, hooked up through Powerline to my families main router. I set it up so whenever I need to restart it (changing settings, updating, etc.) it doesn't mess ev...
- Jul 24, 2021
Oh my gosh, I'm such an idiot. I can just connect to my router using 192.168.1.15. Well, this problem is solved :).
michaelkenward
Jul 21, 2021Guru - Experienced User
QmanRocks wrote:
What I want to know is, is there a way to turn it off inside the router, or do I need to reset something. Any help would be appreciated.
Did you find this?
How do I change my NETGEAR router to AP mode after setting it up? | Answer | NETGEAR Support
