Canth
Apr 15, 2016Tutor
Nighthawk R8000 to Virgin Media Super Hub 2 Connection problem.
My R8000 will not connect to the virgin media super hub at 1.0 Gbps. I have a 150 meg line and through the R8000 I only get 96 Mbps. My local area network is set to the following: Speed = 1.0 Gbps....
- Apr 19, 2016
OK I will look into that. Thanks again.
Canth
Apr 16, 2016Tutor
OK I nipped out today and got a Thunderbolt to Gigabit Ethernet adapter for my MacBook Air so I can test the VM router cables and so on.
First of all I tried every Ethernet port on the VM router and got 1 Gbps (150 Mbps).
Second I tested the cable to the R8000 router and got 1 Gbps (150 Mbps).
I have now found the information you wanted on the R8000:
WAN = 100M/Full
LAN 1 = 1000M/Full
LAN 2 = Link Down (Nothing connected).
LAN 3 = 100M/Full
LAN 4 = 1000M/Full
2.4G WLAN b/g/n = 600M
5G WLAN a/n/ac = 1300M
5G WLAN 2 a/n/ac = 1300M
Nighthawk Firmware Version is V1.0.3.4_1.1.2
Canth
Apr 16, 2016Tutor
I could find no speed setting on the VM hub.
