Canth
Apr 15, 2016Tutor
Nighthawk R8000 to Virgin Media Super Hub 2 Connection problem.
My R8000 will not connect to the virgin media super hub at 1.0 Gbps. I have a 150 meg line and through the R8000 I only get 96 Mbps. My local area network is set to the following: Speed = 1.0 Gbps....
- Apr 19, 2016
OK I will look into that. Thanks again.
TheEther
Apr 16, 2016Guru
You should be able to test the ability of the WAN port to negotiate to 1 Gbps by connecting your Mac to it. Then log into the router with another device and check the speed of the WAN port.
