Canth
Apr 15, 2016Tutor
Nighthawk R8000 to Virgin Media Super Hub 2 Connection problem.
My R8000 will not connect to the virgin media super hub at 1.0 Gbps. I have a 150 meg line and through the R8000 I only get 96 Mbps. My local area network is set to the following: Speed = 1.0 Gbps....
- Apr 19, 2016
OK I will look into that. Thanks again.
TheEther
Apr 16, 2016Guru
You should be able to test the ability of the WAN port to negotiate to 1 Gbps by connecting your Mac to it. Then log into the router with another device and check the speed of the WAN port.
Canth
Apr 16, 2016Tutor
I will try that.
- CanthApr 17, 2016Tutor
I have plugged the Mac into the WAN port and I get 1000/Full.
It still goes back to 100/Full when I put the VM hub in the WAN port.
- TheEtherApr 17, 2016Guru
Are your Ethernet cables straight-through or crossover? It shouldn't matter, but try using the other type than you are currently using between the R8000 WAN port and VM hub. If that still doesn't help, then use the advice of netwrks.
- CanthApr 18, 2016Tutor
My cable is a straight through cat 6. I tried a crossover cat 5E cable and it made no difference.
I got a Netgear ProSafe 5-Port Gigabit Desktop switch and connected it to the VM modem and then the R8000 to the switch.
The results I got are below:
WAN = 1000M/Full
LAN 1 = 1000M/Full
LAN 2 = Link Down
LAN 3 = 100M/Full
LAN 4 = 1000M/Full
2.4G WLAN b/g/n = 600M
5G WLAN a/n/ac = 1300M
5G WLAN 2 a/n/ac = 1300M
I will now look at the netwrks.
