Canth's avatar
Canth
Tutor
Apr 15, 2016
Nighthawk R8000 to Virgin Media Super Hub 2 Connection problem.
My R8000 will not connect to the virgin media super hub at 1.0 Gbps. I have a 150 meg line and through the R8000 I only get 96 Mbps. My local area network is set to the following: Speed = 1.0 Gbps....
  • Canth's avatar
    Canth
    Apr 19, 2016
    OK I will look into that. Thanks again.
