THX-1138's avatar
THX-1138
Nighthawk R8000: Using MAC addresses for blocking DHCP lease requests but NOT access
I have two Wi-Fi networks on two different routers, each with its own SSID, subnet, and DHCP server. Both are upstreamed to my AT&T 2WIRE U-Verse router/switch which connects me to the Internet. I'm migrating my smart devices from one Wi-Fi network to the other. They need access to both subnets. Unfortunately, some of the devices know about both SSIDs, and will try to get a lease from one, and then the other if the first fails.
I want to block them from getting leases on the old network, which is managed by a Nighthawk R8000. Does blocking them by MAC address just keep them from getting a lease, or will it keep them from accessing the network on the blocking router altogether? The former is good, the second bad.
Thanks for any help!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Don't these devices have way to reset them them so that they forget past connections?
    That is the usual way to persuade a phone to connect to a different wifi system.
