guitarpilot's avatar
guitarpilot
Follower
Oct 14, 2024
Nighthawk R8000: WiFi device Connection difficulty following default wifi password change
I recently changed the default wifi password on my R8000 router, and successfully reconnected all of the devices around my home which were previously connected to it. However some devices (namely iPhone) are now frequently being dropped from the router's wifi, and I oftentimes see "Cannot connect to NETGEAR**" when I manually attempt to reconnect my iPhone.
Is this typical following a change to the default wifi password?
What is the maximum number of devices which can be connected to this device via wifi? Is this the issue or is something else going on?
1 Reply
