cap223
Oct 01, 2016Tutor
Nighthawk R8000 Wired connection slower than modem direct connection
My R8000 is doing something strange. I just changed from TWC 300/20 mbps to AT&T Gigapower. With the new AT&T modem connected directly to the PC, I get 195 mbps down and 600 mbps up. However when I p...
- Feb 04, 2017
In AP mode, the max speed between the WAN and LAN ports is pretty much what you are getting. To avoid this speed penalty, use a LAN port. Leave the WAN the disconnected. Unfortunately, you will lose the ability to log into the router. You'll have to reconnect the WAN port to log into it.
Alternatively, you can disable AP mode and use the old school method for APs. Disable the DHCP server and set a static IP address on the router. This address must be in the subnet managed by the AT&T gateway but outside of its DHCP address range. This IP address is what you'll use to log into the router. Continue to leave the WAN port disconnected.
TheEther
Oct 01, 2016Guru
First, log onto the R8000 and make sure the following features are disabled. QoS (but leave WMM on), port forwarding, MAC address clone, block sites, keyboard blocking and traffic metering. All of these features disable hardware-assisted forwarding and force the R8000's main CPU to handle traffic. Unfortunately, the main CPU cannot handle a full 1 Gbps of traffic.
Second, with Gigapower, you should log into the AT&T gateway and enable either IP Passthrough (if you have a NVG599) or DMZ+ (if you have the Pace 5268ac) for your R8000. This will bypass NAT translation for your R8000. You will have to reboot the gateway for this change to take effect.
cap223
Oct 01, 2016Tutor
TheEther All those items on my R8000 are disabled. Any help on enabling DMZ+ on the Pace 5268ac? I've gotten as far as Settings>Firewall>Applications, Pinholes and DMZ. I've selected the r8000 to "host applications through the firewall". I don't know what exactly to choose at Step 2. But I don't want to mess with any settings I am not familiar with.
EDIT: I see the third radio button to enable all applications (DMZplus)
