cap223
Oct 01, 2016Tutor
Nighthawk R8000 Wired connection slower than modem direct connection
My R8000 is doing something strange. I just changed from TWC 300/20 mbps to AT&T Gigapower. With the new AT&T modem connected directly to the PC, I get 195 mbps down and 600 mbps up. However when I p...
- Feb 04, 2017
In AP mode, the max speed between the WAN and LAN ports is pretty much what you are getting. To avoid this speed penalty, use a LAN port. Leave the WAN the disconnected. Unfortunately, you will lose the ability to log into the router. You'll have to reconnect the WAN port to log into it.
Alternatively, you can disable AP mode and use the old school method for APs. Disable the DHCP server and set a static IP address on the router. This address must be in the subnet managed by the AT&T gateway but outside of its DHCP address range. This IP address is what you'll use to log into the router. Continue to leave the WAN port disconnected.
TheEther
Oct 13, 2016Guru
Given that you are not getting anywhere near 1000 Mbps while directly connected to the modem, you should sort that out with AT&T first. Once that's fixed, reinsert the R8000 and check the performance.
