lesyriad
Jun 15, 2017Guide
Nighthawk r8000 with gigabit internet
So I just got giigabit internet installed. Works great when I connect my computer directly to the modem. But as soon as I connect the modem to the router I get about 400-450Mbps :( I have tried ev...
- Jun 23, 2017
SOLUTION FOUND:
So it seems to be an issue with the netgear r8000 itself and the only solution I found was to rewire how the network connected to the r8000.
Before:
R8000 had all rj45 ports used going to various locations around the house.
After:
R8000 connects to modem via wan. 1 port on the r8000 connects to a gigabit switch. All other devices connect to the switch instead of directly to the router. Yes I know this solution makes no sense but I get 920Mbps down from the internet on various devices now. Whats really weird about this solution is that during testings I had only 1 computer connected to the router (directly) yet I only got about 450Mbps. I have no explaination on to why this works but hey Im getting my full speed now.
lesyriad
Jun 15, 2017Guide
Seriously 1gigabit is the "theoretical maximum" WRONG the standard is designed to be able to transfer that fast. So if I have equiptment capable of that speed and eliminate all other factors I SHOULD get that otherwise I was sold a defective product/false advertising. While other factors play into whether you can get that speed. (interferance, heavy network traffic, etc.) I have already stated modem-computer direct connection speedtest gets 1Gbps. Computer-computer on lan file transfer 1Gbps. But modem-router-computer (with only 1 computer on the router) 450Mbps. So why is it that everything does get that 1Gbps in one test and I have shown that my computers/networkcards/etc do get that but the WAN port of the modem is my bottleneck.
michaelkenward
Jun 15, 2017Guru - Experienced User
lesyriad wrote:Seriously 1gigabit is the "theoretical maximum" WRONG the standard is designed to be able to transfer that fast.
Your gigabit Internet is travelling through a gigabit LAN port. All network communication comes with an "overhead" that gets gobbled up by the control of that traffic, among other factors. There was an interesting discussion on that around here a week or so ago. Any test that shows gigabit over LAN is suspect. According to that, over 900 Mbps is pretty good.
But don't take my word for it. (Why should you?)
"Because of factors like network protocol overhead and re-transmissions due to collisions or other transient failures, devices cannot actually transfer useful message data at the full 1 Gbps (equal to 125 megabytes per second) rate. Under normal conditions the effective data transfer over the cable may still reach 900 Mbps at least for brief periods."
"Data rates, including those given in this article, are usually defined and advertised in terms of the maximum or peak download rate. In practice, these maximum data rates are not always reliably available to the customer."
Suppliers of gigabit Internet, or any Internet, wisely describe their service as "up to".
The makers of hardware are equally imaginative in their marketing. But believe what you like.
