Pudgie_japanese
Jul 14, 2017Aspirant
Nighthawk R8000 won't let me connect more than one device
Trying to set up new Nighthawk X6 AC3200 Tri-Band R8000 wifi router and it won't let me connect to more than one device at a time. I am using Apple devices and an XBox. Any ideas?
- Jul 19, 2017
Hi Pudgie_japanese,
You may try to reset the router to factory default.
michaelkenward
Jul 15, 2017Guru - Experienced User
Do you mean that you cannot connect more than one device to the R8000's wifi? (It is confusing to talk about connecting the R8000 to other devices.)
What happens when you try to connect a second device?
