Pudgie_japanese
Jul 14, 2017Aspirant
Nighthawk R8000 won't let me connect more than one device
Trying to set up new Nighthawk X6 AC3200 Tri-Band R8000 wifi router and it won't let me connect to more than one device at a time. I am using Apple devices and an XBox. Any ideas?
- Jul 19, 2017
Hi Pudgie_japanese,
You may try to reset the router to factory default.
Pudgie_japanese
Jul 15, 2017Aspirant
Yes when I try to login to the wifi on my other devices it shows that there is no connection. I can turn wifi off on my phone and my Xbox can take over the wifi, but no more than one device connects at a time.
